I just switched from HR to the Blaze...Loving the Blaze so far, I was in love with my HR and it worked flawlessly. My question is if I run what with the Blaze, what app do I use to connect my Blaze to GPS . Do I have to use anouther app like map my run? Am not very good with Electronic things. If I need to use anouther app, will thbe Blaze automatically connect to it?? Confused:(
Best AnswerHello @Elandan37, the Blaze connects to your phones GPS through the Fitbit app. You start the Run recording on your wrist, wait for the Blaze to say go then take off.
