01-07-2017 18:12
01-07-2017 18:12
I just received my Blaze and after finishing the set up my screen began flashing this message "clock error. Go to mobile app and select a different clock" but now it won't sync to my phone
Best Answer01-09-2017 03:32
01-09-2017 03:32
Welcome to the Forums @Gettingfit1978. I would like to know if you keep having problems with your tracker's display? If you do, I recommend restarting your Blaze and verifying your timezone directly from your phone, then from your Android Fitbit app select a different clock face by doing the following:
1. Tap the Blaze icon in the upper right corner
2. Tap Clock Display
3. Select your clock face
4. Sync
I hope this helps, let me know the outcome. ![]()
