01-04-2018 02:53
01-04-2018 02:53
Bought the Blaze bc friends are happy and now find out it is not compatible with my phone! Unbelievable ! May send it back,
12:30
09:33
01-04-2018
12:30
09:33
Hi there @AnitaST. Great to see you in the Fitbit Community Forums! 🙂
I'm sorry about your LG G5 not being compatible with your Fitbit Blaze 😕
At the moment, this is not a compatible device but if you have an alternate device that you can use for this, make sure that it's compatible and you should be able to use it without a problem. For any update on this, please keep an eye on the list.
Anything else you may need, I'm here to help!
