09-05-2016
10:52
20:35
DavideFitbit
09-05-2016
10:52
20:35
DavideFitbit
Hi folks
I go to the gym six times a week. I each time I go, I run for an hour and I do eliptical for 30 minutes and weight for 20 minutes. As you can imagine, I sweet like hell. Is is fine to wear the Blaze under a lot of sweet?
Thanks lads for your help
Moderator edit: format
Best Answer09-05-2016 11:26
09-05-2016 11:26
Hey so I personally use my fitbit with all my fitness activity - running, convict conditioning, weight lifting, etc. Never a problem. They key thing I would suggest is to keep it clean routinely and definitely rinse the band and watch off after a major exercise period. The Blaze manual covers the best way to clean it, but I've found a mixture of hot and cold water works well for the band, and for the Blaze bit itself, I would take a moist rag and wipe it off as well.
Hopefully that helps.
Best Answer09-09-2016 17:02
09-09-2016 17:02
@aisa A warm welcome to the Community! You may want to check Wear & Care tips so you can take care of your wristband after you've work out. I also found this helpful post from @Julia_G as well as the whole thread that will give you some tips in how to use your Blaze if you sweat too much.
Hope this helps
@MercuFree Thanks for sharing your experience.
