07-29-2017
07:40
05:58
AlejandraFitbit
07-29-2017
07:40
05:58
AlejandraFitbit
I purchased a Blaze 5 days ago. This is my 5th Fitbit. To date, it has died twice, the first time I found it turned on after 24 hours and this morning It showed no signs of life and I read a post saying to hold the left and bottom right button for 15 seconds which turned it back on. Is this normal? I'm not impressed. Second problem, oftentimes when I go to the fitbit app it says that it is not synced to the blaze. Under Bluetooth it shows as not connected. So I have to turn it off and back on again. Is this normal? I'm not impressed and honestly not happy with my purchase.
Best Answer07-29-2017 10:10
07-29-2017 10:10
Have you talked to Fitbit yet? I have had good experiences with them and tech support. They will replace it if need be, sounds like something wrong with the hardware.
08-04-2017 06:00
08-04-2017 06:00
A warm welcome to the Community @Andreaya, thanks for troubleshooting this by yourself and @SunsetRunner for stopping by.
If you are having battery inconveniences, I recommend following the instructions provided in this post and about the syncing, follow the instructions in the Having trouble syncing? post.
I hope this helps, let me know the outcome. ![]()
