11-02-2016
02:16
18:41
DavideFitbit
11-02-2016
02:16
18:41
DavideFitbit
my fitbits battery sufdenly died and only last half an hour know i have tried all the trouble shoot problems and i really need help as it was the centre to my weight loss reigime i was told fitbit would replace it as it is under wareanty but i cant find a helpline number or anything in which to help me. if fitbit helps me i would be glad to continue buying there products otherwise i dint think i could biy fromy then again
Best AnswerHi, @chamberlain, you can find details of how to get in touch with Fitbit Customer Support at contact.fitbit.com.
Good luck!
08:11
08:04
11-02-2016
08:11
08:04
Hi there @chamberlain. Good to see you in the Community! 🙂
As @Julia_G said, you can get in touch with the Support Team and they will be happy to help you getting back on track! Click here for the different contact options.
Let us know if you need any more help!
