Hey, hey, hey @MSingh! It's nice seeing new faces around.
That doesn't sound like normal behavior, as your Fitbit Blaze battery can last up to 5 days but because battery life is affected by use and other settings, actual results may vary. Consider these tips when you want to conserve battery life:
Now for syncing issues, check out this post with further troubleshooting steps. Good luck and keep me posted! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
I have the same problem my blaze has to recharged daily.
@TheresaR215 thanks for joining us! Have you verified the recommendations I posted above? Do let me know! If you've done so to no avail then I recommend contacting our Support Team for further assistance. They definitely have the tools to take a deeper look into your tracker's behavior. Remember to mention them all the troubleshooting steps you've done to fix this. By doing that you'll be helping them to provide you with a quick follow up.
If you haven't already I suggest doing a restart:
Keep me posted my friend!
