Blaze battery draining
Hi ... I just bought Fitbit Blaze last week. I only charge it by connecting the cradle to my laptop. Battery drained to 50% after 1 hour (I don't use it. Just place it on the table). Shutdown the Blaze also results the same (fully charged Blaze goes to blinking battery icon, after I restart the Blaze). Battery won't last more than a day, if I used it in running/workout.
I have followed the charging instruction, restart the Blaze, shutdown, cleaning the charging pins, choose minimum setting (as to reduce battery consumption), and reduce sync activity. It just don't work .. T_T
Any help brothers and sisters?
Disappointed.
1 REPLY 1
A warm welcome to the Community @heidi2070.
Thanks for troubleshooting this by yourself. Since the troubleshoot you tried didn't work, I recommend keeping an eye on your inbox for further assistance.
Catch you later. Robot wink
