Blaze battery issues
The Forum is littered with battery issues. How can you build a device and sell it to the public and make no allowance to change out a bad battery? For the price of a Blaze, it is not a “throw away” item. If the battery issue is not addressed, I don’t see there being a market for very long.
1 REPLY 1
Thanks for your participation in the Community @Flash56.
If you are experiencing battery issues with your Blaze, I recommend taking a look at this post and follow the instructions provide there. Also, I appreciate the feedback provided about this problem.
Catch you later. Smiley Happy
