Blaze battery life issues
ANSWERED
Have owned my blaze since August 2016 and have had no issues, but lately the battery life has gone from lasting 3+ days to just one day, so now having to charge daily.
Can anyone suggest anything I can do?
1 BEST ANSWER
Accepted Solutions
Hi thanks for the advice.
It it seems to be sorted now. Looks like it was something to do with the latest update for iPhone causing syncing issues and draining the Blaze battery, as it was constantly trying to sync. Followed advice from another post on here, went into settings on iPhone, Bluetooth and selected option to forget this device. Then reconnected to Blaze on Bluetooth. All seems ok now 👌🏻 Thanks for the advice though!
4 REPLIES 4
You can try restarting it: restart
Thanks 👍🏻 I'll give that a go and see if it makes a difference.
A warm welcome to the Community @Djlee01 and @SunsetRunner thanks for stopping by.
If you are having problems with your tracker's battery life, I recommend following the tips provided in this post
I hope this helps, let me know the outcome. Woman Happy
