07-31-2018 08:15
07-31-2018 08:15
In the last few weeks my blaze battery has begun to need charging from 4-5 days to much less. Over the last 2 days it barely holds a charge for more than 6-8 hours. I've cleaned the charging points, made sure it's charged correctly for the correct length of time and have also reset it. Why is this happening and how do I rectify it? I cannot afford to purchase a new one and certainly don't expect this issue on such an expensive item. Any advice would be gratefully recieved. Thanks.
Best Answer07-31-2018 13:21
07-31-2018 13:21
There are so many people that are having this issue. I honestly can’t believe everyone’s battery maxed out life at the same time. Mine is older, as I got it when it was first released in February of 2016. The battery was perfect until June (4-5 days between charges) then has gotten where it lasts between 1 to 2 days. I have not changed my usage pattern it just went downhill.
07-31-2018 13:30
07-31-2018 13:30
This is exactly what seems to have happened to mine. My blaze is an older version too. Same timeframe too Hythe sounds of it. Was happily charging every 4-5 days until earlier this year and since yesterday I'm lucky to get 6 hours out of it. Screen is intermittently unresponsive too but didn't connect the dots until earlier. Shocking how so many seem to have stopped working properly at the same time. 🤔
Best Answer07-31-2018 13:50
07-31-2018 13:50
This is exactly what seems to have happened to mine Blaze, too 😞
Best Answer07-31-2018 15:45
07-31-2018 15:45
Similar issue. Battery is not holding up for loan and if I try to charge it I get a fully charged symbol. The full charge then remains for 6 hrs before draining completely. Not sure if this is pure battery or battery plus charger issue.
