07-12-2019
21:23
19:08
YojanaFitbit
07-12-2019
21:23
19:08
YojanaFitbit
I am not able to charge my blaze peoperly Plz give me a solution
Best Answer07-23-2019 19:07
07-23-2019 19:07
Nice to see that you're digging into the Forums @raja_rjlk, let me give you a warm welcome to our Community. Sorry for the delay.
Let's try a couple of steps to make your Blaze to charge:
I'd suggest to clean the contacts of your Blaze. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts, do not scrape them with anything metal because this may damage the plating and result in corrosion.
Please try to restart your it once again. How are you changing your Fitbit? We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. Did you have issues before with the charging cable?
Please take a look of these recommendations to charge your Fitbit too.
Let's give it a try and please keep me posted. ![]()
07-23-2019 19:07
