05-15-2018
09:03
04:18
AlejandraFitbit
05-15-2018
09:03
04:18
AlejandraFitbit
12 hour life and less. Thermometer over a triangle symbol displayed. Overheating?
04:21
08:39
05-18-2018
04:21
08:39
A warm welcome to the Community @Mwd2108.
Could you please be more specific about the issue you are experiencing with your Blaze? Is it overheating when you put it to charge or is it just showing the thermometer icon? If it is overheating, I recommend not using your tracker, now if it just showing the thermometer icon you can try to restart it.
Now about the battery, if it isn't lasting the time it should, I recommend taking a look at this post and follow the instructions provided there.
Let me know the outcome. ![]()
