02-12-2019 19:58
02-12-2019 19:58
Blaze battery just started draining fast, and is getting faster as the days go on. I’ve cleaned contacts, restarted several times to no avail. I would think a fitness tracker would last more than 2 years but who knows.
Best Answer02-12-2019 20:12
02-12-2019 20:12
Hi, @LDBidwell! Unfortunately, much like most electronic devices with lithium ion batteries, these trackers have a finite shelf life. You can take care of them and squeeze a bit more life out of them, but most only last 2 to 3 years on the original battery.
MakMak | Community Council
Best Answer02-12-2019 20:14
02-12-2019 20:14
Is there a replacement battery?
Best Answer02-12-2019 20:18
02-12-2019 20:18
Not from Fitbit, but you could google it and see if there is anyone around who does it, or if there's a way to do it yourself. Good luck!
