05-10-2017 19:23
05-10-2017 19:23
A couple days ago my blaze quit working completely. After figuring out how to restart it, it seemed to be working ok....i thought. I have since restarted it several times because the display isn't working. It is either completely blank or every once in a while it will show several lines running from the top to the bottom. After restarting it, it usually works about a minute and then it quits again. It is still tracking my steps according to the app. Any ideas?
Best Answer05-10-2017 20:42
05-10-2017 20:42
Welcome to the forums!
I know you said you restarted it, but doing in consecutively 3 times can help.
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
Best Answer05-12-2017 06:19
05-12-2017 06:19
A warm welcome to the Forums @SunsetRunner and @WendyB thanks for stopping by.
I would like to know if you keep having inconveniences with your Blaze display? Restarting the tracker worked or no, have you already contacted our support team?
Hope to hear from you soon. ![]()
Best Answer05-12-2017 06:56
05-12-2017 06:56
Best Answer05-17-2017 04:05
05-17-2017 04:05
Thanks for the information @SunsetRunner. I am glad to hear that you have already contacted our support team. If you need anything else, do not hesitate in posting it.
See you around. ![]()
