12-04-2018
05:37
11:05
FerdinandFitbit
12-04-2018
05:37
11:05
FerdinandFitbit
Is anyone else having trouble with the touch screen display? The buttons on my blaze are still working but I cannot use the touch screen to swipe. I tried resetting it by holding down the left side button and then the other buttons. It is not resetting. Any help would be appreciated
Moderator edit: Updated title for clarity
11:04
10:42
12-05-2018
11:04
10:42
Welcome to the Community Forums @Sal3721! 🙂
I'm sorry to hear you're having problems with the display on your Blaze not responding. Thanks for trying to restart your Blaze. I'll be happy to help you out!
Since restarting it seems not to make any difference, you can try to set up your Blaze as a new device. For this, go to the Account section at the top right corner on the Fitbit app and select the option that says "Set up a new device". Follow the on-screen instructions and once you're done, your tracker should be syncing without a problem.
