03-11-2018
10:53
12:18
FerdinandFitbit
03-11-2018
10:53
12:18
FerdinandFitbit
Blaze is frozen on logo screen. Resetting does nothing! After pushing and holding buttons, screen blinks once and then unresponsive. I placed on charger, no change still frozen. Help!
12:18
05:40
03-11-2018
12:18
05:40
Hi there @Chefdmc. Good to see you in the Fitbit Community Forums! 🙂
I'm sorry you're having problems with your Blaze not responding 😕 Thanks a lot for restarting and putting it to charge though!
Since doing that didn't help, I would recommend leaving the tracker to drain the battery and once this happens, put it to charge and see if it lights up and works as it should. If that doesn't happen, let me know and I'll be happy to provide further assistance.
Anything else, I'm here to help!
Best AnswerHello Chefdmc,
Have you solved your issue? I'm having the same issue. I've left it 2 days without charging it and when i'm trying to charge i get the same frozen logo display :(.
I was wondering if you managed to solve it and how.
Thanks
