It's great to have you here @Honie68! Thanks for the restart and for buying another charger. I would like you to double check that you've done a restart by following this procedure. Additionally, if you get your Blaze's display to work, you can try these syncing steps.
P.S. I've shared your post with Customer Support, they should reply back to you within the following days.
Hope this helps!
