07-26-2019
14:27
14:56
07-26-2019
14:27
14:56
Charged my Fitbit today fine. Went to set an alarm for work and it just went off. The green light still on at the back. Pressed the buttons and side and nothing happens. Plugged it in to charge and nothing. Anyone any suggestions?
Best Answer07-26-2019 14:59 - edited 03-27-2024 12:02
Welcome to the Community Forums @han_98! Thanks for reporting your Blaze's behavior.
If your device isn't turning on, I recommend restarting your Blaze. Also, clean the charging contacts on the back of your Fitbit, since over time the contacts can accumulate dirt and debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
