11-04-2020 17:26
11-04-2020 17:26
I used to see my active minutes up until they put in the active zone. Now i get nothing. Customer support says it is only available on the new devices. Their response was to post something here instead of forwarding this to their respective department. Very disappointed in Fitbit and will consider other smartwatches in the future.
Best Answer11-05-2020 03:44
11-05-2020 03:44
@rlc2673 The Blaze is nearly 5 years old. It's likely not able to do some of the newer stuff like active zones. What do you want them to do? I know my Blaze doesn't have SP0, and also can't auto pause GPS workouts like even the Versa 1 can. It's just older technology.
11-05-2020 03:44
Best Answer11-22-2020 21:38
11-22-2020 21:38
@rlc2673 no screen shots of your dashboard?
Do you get any active minutes durring an exercise?
Best Answer07-25-2021 17:04
07-25-2021 17:04
I expected the app to calculate the zones from the data uploaded to the fitbit servers. Why should it matter what device collected the data?
Best Answer07-26-2021 10:04 - edited 07-26-2021 10:05
It matters what device because the older models do not have the same sensors as the newer models. This may be the reason.
Of course being fitbit users, we know little about the behind the scene data.
Best Answer07-26-2021 10:44
07-26-2021 10:44
We are talking about heart rate data fitting in specific zones for a length of time. This is not a device issue, it's a software placement issue. In other words, the watch should collect the data (those that have HR sensors) and the app should calculate the results. This thread is specific to one issue - the Blaze, which has a(n) HR sensor, not having its data included in Zone minutes. Age of the device has nothing to do with it. It is an arbitrary decision made by fitbit to sell the Sense. BTW, I have both the Blaze and the Sense. I wear them for different reasons and, most of the time, the transition between the two is seamless, except for Zone minutes. The data shows up on the Zone chart, but Zone minutes is 0.
07-26-2021 11:03
07-26-2021 11:03
It really doesn't matter what we are talking about, none of us fitbit users have much, if any insight on the algorithms.
I know that with every new model, the heart rate hardware gets updated.
Best Answer07-26-2021 12:16
07-26-2021 12:16
I get that fitbit users don't have insight into how these devices work, so maybe it's time for someone at fitbit to chime in. Speculating doesn't help.
Best Answer08-01-2021 03:27 - edited 08-01-2021 03:30
Support rarely posts anything in the community. You could contact support and they will quote the user manually or the fitbit Help pages @Jim1164. Or we can go to the help pages ourself.
According to the Blaze User Manual, it monitors Active Minutes, not Active Zone Minutes.
Active Zone minutes are on trackers that are running the Fitbit OS.
What are Active Zone Minutes or active minutes on my Fitbit device?
How do I earn Active Zone Minutes
Active minutes looks at the users activity, rather than depending on the HR. Since not all of the older trackers record HR.
How do I Earn Active MinutesEarn active minutes through 10 minutes or more of continuous moderate-to-intense activity.
How does my device calculate Active Minutes
Fitbit devices calculate active minutes through metabolic equivalents (METs). This metric, which factors in your body mass, is used to estimate exercise intensity. METs are calculated through a ratio (source😞
What is a MET
1 MET is the rate of energy you expend during rest or sitting quietly, while you typically expend 3 METs or more during a moderately-intense activity such as walking. You earn active minutes for activities at or above about 3 METs.
Best Answer08-01-2021 03:31
08-01-2021 03:31
Basically, the Blaze lacking an operating system does not have Active Zone Minutes.
08-01-2021 07:48
08-01-2021 07:48
This is why I said the watches (Blase, Sense, etc.) should only collect data and leave the app, whether web, pc, phone) to do the calculations. That way all resonsibility for advancements (e.g. Zone Minutes) fall on the app and all the watches become backward compatible, if they have the appropriate sensors, of course.
Best Answer08-01-2021 11:48
08-01-2021 11:48
@Jim1164 My Versa 1 didn't have zone minutes until a firmware update last October or so. Zone minutes is on the watch, not the app or server.
Best Answer08-01-2021 13:05
08-01-2021 13:05
I get what's wrong - the Zone Minutes are calculated by the watch. I don't dispute that. I'm just saying fitbit should have the app process the data, whether in addition to or instead of the watch, to be backward compatible. That way, for example, your Versa didn't need the firmware update. I have both a Blaze and a Sense. I understand that my Blaze does not have Zone Minutes, and I don't care about that. What I do care is when I use my Blaze and sync its data with the app, which has Zone Minutes, that the data from my Blaze gets added to those Zone Minutes and when I move to using my Sense, that those Zone Minutes sync to the Sense.
Best Answer08-02-2021 10:35
08-02-2021 10:35
@Jim1164 That's kind of like a feature request. Nothing gets done as easy as making a post about it around here. You would have to make a thread in the feature request section, and get like thousands of upvotes to get Fitbits attention.
Otherwise, this is just a community forum. We are just users like you, with Fitbit moderators around to keep the piece as well as help with minor issues.
And as old as the Blaze is, you rarely see moderators in this section anymore.
That would be cool if they did that, as I have a Blaze too. But I don't see it happening.
You haven't been able to change the Blaze clock faces on the IOS app for Months now and Fitbit knows it. But there has been no updates or solutions.
IMO they are not real concerned with the old Blaze anymore.
Best Answer08-02-2021 11:41
08-02-2021 11:41
Best Answer08-02-2021 11:44
08-02-2021 11:44
There already is a thread for active minutes on all devices. With 32 votes.
However we have people who love and others who hate active minutes.
No, it is usually around 600-700 votes when a request starts to get active that will attract the attention of the developers.
08-02-2021 11:57
08-02-2021 11:57
I agree. Fitbit needs to do what it can to promote customer loyalty by making at least their app backward compatible. That's all I'm asking. I don't care that my Blaze doesn't have Zone Minutes, so I don't need fitbit to release an update. Fitbit users will buy a new watch when they need to, they shouldn't be forced to because a new watch has a new "fake" feature - face it, Zone Minutes is nothing more than organizing heart rate data into "zones" and all watches that collect heart rate data can be included.
