09-28-2017
07:51
04:58
AlejandraFitbit
09-28-2017
07:51
04:58
AlejandraFitbit
My Blaze quit keeping up with my heart rate a couple of days ago. On the Blaze there is no register on my heart rate, and the resting rate reads 62. One green light is blinking but extremely faint in color. The other light looks dead. I have tried all reset options with no luck. Any ideas?
09-29-2017 05:00
09-29-2017 05:00
Hey there @Bstruitt, it's great to see new faces, welcome! And thanks for troubleshooting this by yourself.
Please confirm that there are the steps you followed to restart your Blaze:
If these steps are not the ones you did, I recommend restarting your tracker by doing them. Also, check that the heart rate feature is on or auto.
Hope to hear from you soon. ![]()
Best Answer09-30-2017 05:11
09-30-2017 05:11
Yes, I did this and it is still not working.
10-02-2017 04:05
08-02-2018 17:17
08-02-2018 17:17
I am also having the same problem, I tried resetting my Fitbit but the green lights are pretty much dead and the battery is still full
06-11-2019 09:08
06-11-2019 09:08
Mine has started doing this too, I've reset and restarted, any viable solution, apart from buying a new one?
Best Answer06-11-2019 10:19
06-11-2019 10:19
Best Answer06-14-2019 08:32
06-14-2019 08:32
