08-13-2018
10:31
04:48
AlejandraFitbit
08-13-2018
10:31
04:48
AlejandraFitbit
Newbie here, seem to be having an issue with green light staying on constantly.
I have tried switching the heart rate monitor on On,Off and Auto all three options still have the green lights on permanently. I have re-booted the device by holding the left hand side and bottom right button simultaneously, which did reboot but with no difference to the lights still being on. I have been to shutdown the device in the settings section. Hurrah green lights off. Boooo, switched back on and green lights are still glowing like a Kryptonite nightmare. Has any one else managed to solve this battery blasting crime?
04:50
08:08
08-16-2018
04:50
08:08
It's great to welcome you @pjk1953.
Thanks for troubleshooting this by yourself. If you want your heart rate sensor off, I recommend selecting the "Off" option in heart rate, since if you select "On" the sensor will be blinking constantly. You can also select "Auto" in order to see the sensor working only while you are wearing the tracker.
Catch you later. ![]()
04:04
08:08
08-17-2018
04:04
08:08
Thanks for the information @pjk1953.
Since the steps provided didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. ![]()
