There are half-dozen threads on Blaze innaccuracy for steps/distance.
We're waiting for a software fix. Might see Donald Trump win La Raza's "Man Of The Year" award before it gets here.............LOL
@Fands wrote:
I rec'd an email from customer service yesterday...they are replacing my Blaze..it has been consistently shorting my step count milage for over 2 weeks. And now i have intermittent fast battery drainage..hopefully it will all work right with the new one.
Your battery problem will probably be better. You'll probably still that the inaccurate step count until they try to fix the software issue.
Welcome to the Community @EnzaneB and @MikeS1971, @Fands, @Corvettekid and @BeccaMP it's great to see you around.
I would like to know if you keep having problems with the accuracy of your Blaze? If you do, I recommend restarting your tracker and after the restart process, test it.
I hope this helps, let me know the outcome. ![]()
Best AnswerHi @AlejandraFitbit,
If I restart my Blaze part way through the day, will it delete the activity for today so far?
Is it best to do a reset at night / first thing in the morning?
I've noticed a significant decrease in the steps tracked on my Blaze over the last two weeks compared to before. I've only had the thing two months today, and now, the same activity is only showing I did half the number of steps!
Thanks,
Thanks!Thanks!
It's great to see you around @Lozzypop and @MikeS1971. No, don't worry, a restart shouldn't take away your information. If you see that your stats are not being accurate at all, as mentioned in the previous post, feel free to contact our support team, for a faster response you can contact them via phone or chat.
See you later. ![]()
