06-14-2023 03:27
06-14-2023 03:27
The fitbit blaze device keeps slipping out of the metal frame. There were 4 small rubber pieces inside the frame that kept the screen fixed, but now they're worn out. Pls suggest quick fixes.
Best Answer06-14-2023 07:32
06-14-2023 07:32
Hi @Device_help the fastest way would be to purchase another band. The problem you might run into is that the Blaze was retired quite a few years ago and Fitbit no longer makes them. You might find a generic band, but there is no guarantee that it will be a proper fit.
Best Answer07-17-2023 07:22
07-17-2023 07:22
Look on Amazon, they're cheep. When I had my blaze I bought several frames and bands.. Made it easy to switch
