04-18-2017
19:06
13:01
DavideFitbit
04-18-2017
19:06
13:01
DavideFitbit
got it out of the box brand new and it wouldn't charge.
@adavis0222 It won't show a charging icon until it is setup. Just let it sit in the dock for a few hours and then try setup. When putting it in the charger, make sure that the Blaze contact points are in line with the charging pins in the charging dock. You should hear a little click.
Best Answer@eeram23, im not sure wyat 6o7r saying or asking?
@adavis0222 what you will notice while connecting thr tracker to the charger, will be a slight vibration.
