Recently upgraded to Blaze and honestly, what a mistake. This is my third one. The first two wouldn’t charge at all (after setup etc) so the store I purchased it from replace them, twice. Now I’m losing my wits and I’m too embarrassed to go back and ask for another exchange.
Ive charged it a couple of times and it was fine, until it randomly died yesterday. I charged it overnight, everything seemed fine, completely dead today. The screen comes up when I put it in the charger, battery flashing as low. Nothing happens when taken out. Exactly the same as the previous two I had. No reboot or other methods suggested in the 101 threads that I’ve read works. Is there a solution, or is it just another dodgy one?
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
This sounds like it might be the problem. It important how you charge it
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
http://help.fitbit.com/articles/en_US/Help_article/1799
Wendy | CA | Moto G6 Android
Best AnswerDone that. Tried doing it with my previous ones. My other half also tried, following the guide.
Best AnswerIt’s not wet. I have tried all different USB ports, plugs devices. I tried all surfaces and all alignments. I’d do anything now to show my face up at that store, again.
05:07
05:48
04-08-2018
05:07
05:48
A warm welcome to the Community @slavic-frost and @WendyB thanks for stopping by.
I appreciate your efforts in trying to fix the battery issue you are experiencing. Since the troubleshoot provided didn't work, I recommend keeping an eye on your inbox for further assistance.
See you around. ![]()
