Blaze not charging
I've noticed my blaze isn't holding charge and I have checked the charger with a friends and it works but looking at the back of the blaze where the contact points are the two points at left side seem to have holes in the middle. Does this mean it had worn through!? . Anyone else had this problem. Surely the contacts shouldn't have done this.
3 REPLIES 3
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
Community Council Member
Wendy | CA | Moto G6 Android
I've tried all the solutions you have mentioned. But the problem seems to
be in the contact areas on the blaze. The back 4 contact ports look damaged
on the left side like the pin from charger has gone through it.
It's great to see you here @J6nst and @WendyB thanks for the input.
I appreciate all the efforts in trying to fix this issue. Since the steps you tried didn't work, I've gone ahead and escalated your case to our support team, for them to take a deeper look at this. Please keep an eye on your inbox for further instructions.
Keep me posted. Smiley Happy
