10-05-2018
22:38
09:06
AlejandraFitbit
10-05-2018
22:38
09:06
AlejandraFitbit
Seems to be a common problem but I dont' see the magic path to get mine up and running
Thanks. appreciate the help.
10-06-2018 12:40
10-06-2018 12:40
Well situation has been resolved.
Plug charger into PC - no work.
Plug charger into Samsung phone charger (new) - no work
Plug charger into USB plug on power strip - now it works.
Up and running. Just not sure how I'm going to charge it while on business trips. I don't usually travel with a power strip.
10-06-2018 10:57
10-06-2018 10:57
Welcome to the forums!
I would diffidently exchange it through Amazon
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
10-06-2018 12:40
10-06-2018 12:40
10-06-2018 12:41
10-06-2018 12:41
Thanks Wendy. if my wife didn't happen to try the USB port on a power strip - your advise was my next step. Cheers.
10-07-2018 09:07
10-07-2018 09:07
A warm welcome to the Community @JW_Go and @WendyB thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and I am glad to see here that your issue has been resolved and that your tracker is now working properly. If there is anything else we can help you with, do not hesitate to post it.
Happy stepping!
