07-15-2017 08:46
07-15-2017 08:46
I pop the electronic device out of its frame once a week to give it a wipe clean. I've been doing this for over a year. Today - the device will not clip back in ... any suggestions?
07-15-2017 14:29
07-15-2017 14:29
A warm welcome to the Community @Richardza! I would like you to make sure that you're properly introducing your pebble into the frame, you may want to check the video posted in this article How do I change my wristband?.
Do you see if it's loose in the frame or the buttons aren't working?
Keep me posted!
07-16-2017 12:01
07-16-2017 12:01
07-21-2017 05:45
07-21-2017 05:45
Thanks @Richardza! The link I provided above has all the tips in how to properly change the wristband for each tracker, you just need to select Blaze.
It sounds pretty weird that it's no longer fitting into the wristband, could you provide me with a screenshot of how your tracker looks like into it?
Keep me posted!
