04-18-2016 10:13
04-18-2016 10:13
06-05-2017 08:02
06-05-2017 08:02
18:16
10:15
06-05-2017
18:16
10:15
@Sakhmet thanks for getting back to me! Hey, as a last resort please try re pairing your Blaze to your mobile device. However, do not unpair your tracker before.
Follow these steps to go through the set up process again. Hope this helps.
Looking forward to your new comments! ![]()
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
08-05-2017
16:26
13:58
MariamV
08-05-2017
16:26
13:58
MariamV
"After about 2 weeks it just started working again. Idk why, I didn't do anything different, just kept trying the same thing over and over again. Accepted Solution"
I was directed to the above as an Accepted Solution presumably by the Board Moderator. Does Fitbit really expect its customers to sit around with a dysfunctional $200 device for two weeks in hopes that it will mysteriously start working?
Moderator edit: format
08-07-2017
14:05
10:14
08-07-2017
14:05
10:14
@MkUltra thanks for stopping by! Please note that the "Accept as Solution" button will only appear to the original author. If you did not create the topic, you will not be able to mark a post in that thread as a solution. For more info on Accepted Solutions, click here.
Have you followed any troubleshooting steps? Do let me know! Also, I recommend troubleshooting your Bluetooth using the steps @Rich_Laue posted here. If that doesn't do it, then I suggest setting up your tracker again by following these steps.
Keep me posted with the outcome! ![]()
09-28-2017 07:15
09-28-2017 07:15
Did everything, several times.
Everyday I have to reboot my blaze.
I agree, It's a very expensive watch to spend so long with these issues.
Kind regards,
Diana Barão
19:32
10:15
10-04-2017
19:32
10:15
It's nice to hear back from you @Sakhmet! Sorry for the delay in my response; I wanted to step in to this thread and check if the syncing issues you were experiencing with your Blaze have been resolved by now? Do let me know. ![]()
I'll be looking forward to your new comments!
10-05-2017 10:12
10-05-2017 10:12
I am having the same issue. I go through the trouble shooting steps multiple times a day now. This started a month or two ago. It wasn't having any syncing issues before.
10-23-2017
16:55
10:14
10-23-2017
16:55
10:14
@kyla_s thanks for stopping by and for troubleshooting this issue beforehand. That doesn't sound like expected behavior.
Check out this article for further troubleshooting steps. Hope this helps!
Keep me posted. ![]()
Best Answer10-24-2017 00:26
10-24-2017 00:26
10-31-2017
14:58
10:14
10-31-2017
14:58
10:14
Awesome news, @Sakhmet! Thanks for sharing this with us.
To set up your replacement Blaze using the Fitbit app do the following:
Hope this helps. Keep me posted! ![]()
