After I complete my treadmill workout and select done on the watch, when I sync my phone the data is gone as if I never started it. I have done all updates and resets. Any suggestions?
A warm welcome to the Community @Czbarron90. Are you selecting the activity directly from the tracker, are you manually logging it or doing both? Could you please provide me with a screenshot of the information you are seeing? Now, if the issue is directly with syncing, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there.
Hope to hear from you soon. ![]()
Hello! Yes, I am selecting the activity directly from the tracker. After I finish and syncing is complete in the app everything is gone.
Having trouble getting the screenshot to paste.
Thanks for the update @Czbarron90. Have you tried to restart your Blaze? If you haven't, I recommend restarting it by doing the following:
After this process, test your device.
That did the trick! Thank you!
You are welcome @Czbarron90, I am glad to hear that your tracker is now working properly. If you need anything else, do not hesitate in posting it.
Keep the stepping up! ![]()
