04-06-2018
14:23
04:26
AlejandraFitbit
04-06-2018
14:23
04:26
AlejandraFitbit
I have a degree in computing and write software. This Blaze device is the worst I have ever purchased and, frankly, I'm thinking of binning it. I've had it about three weeks and have only been able to use Bluetooth about three times. What a load of rubbish. I've shut it down eleven times; removed and reinstalled the software six times, restarted my tablet fourteen times. It only works when it feels like it and I regularly get messages like "Your sync has been scheduled" Spits in bin.
04-19-2018 09:18
04-19-2018 09:18
The Windows 10 laptop won't sync with it either
04-19-2018 12:17
04-19-2018 12:17
04-23-2018
08:11
07:56
04-23-2018
08:11
07:56
A warm welcome to the Community @JHRA, @pokyflash great to see you here. I would like to know if you keep having syncing issues? If you do, I recommend following the instructions provided in the Why won't my Fitbit device sync? article.
@Kingell and @Bright2 I would like to know if you were contacted by our support team, have they offer you a solution?
Keep me posted.
04-23-2018 12:44
04-23-2018 12:44
04-23-2018 13:25
04-23-2018 13:25
Hi, I have tried deleting the fitbit off my computer and reinstalled it and the blaze still wont sync. It just keeps searching and cant connect to it to give me the four digit code. I have the fitbit near the computer. I've even uploaded the app on my sons ph and its requesting me to turn the Bluetooth on (which I did) but it somehow drops off and then app asks me to purchase some other gadget to sync it in. I don't know why I need too as I've never had to before. When I add my hubbys fitbit to my ph, it syncs in ok but his steps etc ends up on my details and it mucks our individual steps up. Quite frustrating.
My other option is to take it back to the shop and get a replacement one.
04-25-2018
04:37
07:56
04-25-2018
04:37
07:56
Those are great news @Bright2, I am glad to hear that your Blaze is now working properly. If you need anything else, do not hesitate to post it.
Now @JHRA, since your issue is directly with pairing, I recommend restarting your Blaze and make sure you are doing the following from your Fitbit app:
Let me know the outcome.
04-25-2018 13:26
04-25-2018 13:26
Thank you. I've already tried that and still doesn't work. Turn off fitbit, removing fitbit from computer, deleting app, re-installed, added fitbit .... still doesn't work. Might be time for a new blaze instead
04-25-2018 14:01
04-25-2018 14:01
04-25-2018 19:53
04-25-2018 19:53
Ok I will try thank you. Otherwise I know the shop will just replace it with a new one which hubby is currently on his third one atm.
05-02-2018 03:39
05-02-2018 03:39
I started this entry by complaining about my Blaze. I find it's more reliable if I keep it charged DAILY!! Not very good but there you go. My wife's is a different model and much more reliable. Personally I wouldn't recommend this particular model to anyone.
