My Blaze is nearly 4 years old.
Yesterday, the screen froze on notifications, I had to do a reset & then it showed low battery (it was charged the night before). I charged it again last night, but screen totally blank & no flashing green lights. App is showing that it’s fully charged. Have tried several more resets: it vibrates after about 2 seconds, flashing green lights come on briefly & then go back off and no Fitbit logo on screen ... any other ideas or is it time for a new one?
Best AnswerHello and welcome to the forums @SunsetRunner
Four years is a really long time. My own Blaze made it about two years. You should take a look at the Fitbit Store and see the new styles that are available. The Versa series took over when the Blaze was retired. The Inspire series is the newest and the Inspire has an optional clip so it can be worn off the wrist. So many new options for you to view and new colors. Let us know what you do!
Welcome to the Fitbit Community @SunsetRunner ! It's nice to see you around @Odyssey13 !
@SunsetRunner thanks so much for taking the time to troubleshoot the issue you're experiencing with your Fitbit Blaze display not turning on. I appreciate your efforts to fully charge and restart the device several times. Since the steps you tried didn't work, I've gone ahead and escalated your case to our Support team, for them to take a deeper look at this and check your warranty options. Please keep an eye on your inbox for further instructions.
@Odyssey13 thank you for your feedback!
