Blaze replacement
ANSWERED
Can anyone tell me how much charge is in the blaze when you first receive it?
I have just had delivery of a brand new Blaze and trying to set it up again but having difficulties again already!! if i remember correctly when you put it in the charging dock it has a picture of it charging ?  If so it isnt doing that and i think i may have a dud again.  I was suprised that fitbit didnt send out a new docking port too?
any advice would be much appreciated
regards
russell
1 BEST ANSWER
Accepted Solutions
Hi
When connected to the charger / usb, there's a animated battery icon on the screen, indicating it's charging.
Just in case, make sure to directly charge using a usb port, not a usb hub if using a usb hub. Cat Embarassed
1 REPLY 1
Hi
