12-20-2018
19:54
07:51
LanuzaFitbit
12-20-2018
19:54
07:51
LanuzaFitbit
My Fitbit blaze battery is discharge so early
Best Answer12-21-2018 07:50
12-21-2018 07:50
Welcome to the Forums @Pawan_sharma.
Let me help you figure out what is going on with your Fitbit Blaze. I will be moving this board to the Blaze board as I think it is better suited for it.
The first thing I'd recommend that you try to follow the steps listed in this help article. They should definitely help you in improving the Blaze's battery.
Keep me posted on how it goes or if you have any further questions.
Best Answer12-26-2018 20:43
12-26-2018 20:43
Best Answer01-03-2019 11:33
01-03-2019 11:33
Hello @Pawan_sharma.
Thanks for trying all of those tips to improve the battery.
In this case I've reached out to the support team so that they can help you look into what could be happening. They'll be happy to help you out.
Let me know if you have any further questions.
