07-12-2021
07:35
17:22
07-12-2021
07:35
17:22
My much liked Baze battery is dying and I'm told it can't be replaced. What do you recommend to replace it?
Hi @R-green take the quiz to find your perfect Fitbit - click to go there. The Versa series is what replaced the Blaze. There are so many great styles out there. I have the Luxe and love it. Hope you find one that suits all your needs!
Best AnswerHow do I repair old blaze Fitbit?
Best AnswerHi @maheshshinde these devices can't be repaired thru Fitbit. If you have one that needs to have parts replaced, you'd have to dig around the internet. Sometimes repairs cost more than a new device.
Best AnswerI've gone thru 3 devices. Each one has failed and could only be replaced. I've owned the Blaze for 3 years, 3 months and it is failing to hold a charge and syncing problems. It no longer records my sleep and I charge it almost every other day. Because of all the data I've collected, I hate to move on but I can no longer deal with planned obsolescence. In the past, I've worked with tech support on the issues but i will not bother with this one. BTW, i do consider myself tech savvy and am presenting an objective assessment...
Hi @halbizo some people have found places that sell batteries, so if you feel confident, you could try that route.
Best AnswerHi, you are lucky your battery lasts for more than one day! Over the last month, my Blaze battery has deteriorated from being similar to yours to having to be charged every 8-9 hours. About 2 days ago I got an overheat indication after about 6 mins on charge, it was red hot! I really like the Fitbit Blaze but it is too much hassle to keep charging every 8 hours or so. PJLKSA
