11-12-2016
20:35
07:11
AndreaFitbit
11-12-2016
20:35
07:11
AndreaFitbit
The battery on my blaze died this morning and won't charge, it doesn't even display the Fitbit home display.. seems to be completely dead.. any thoughts? Already cleaned it as well....
Best Answer11-13-2016 05:07
11-13-2016 05:07
04:55
09:49
11-16-2016
04:55
09:49
A warm welcome to the Forums @Churrihn504 and @Rich_Laue thanks for stopping by. I would like to know if you keep having problems charging your Blaze? If you do, I recommend restarting your tracker. After the restart process, put your tracker to charge.
Let me know how it goes. ![]()
11-16-2016 05:21
11-16-2016 05:21
05:23
09:49
11-16-2016
05:23
09:49
Those are great news @Churrihn504. I am glad to hear that your Blaze is now working properly. If you need anything else do not hesitate in posting it.
Happy stepping! ![]()
Best Answer11-16-2016 13:14
11-16-2016 13:14
Hi, I've just experienced the same thing today with mine, it died completely, put it in the charging cradle for the past 12hrs and it's not charged at all, still dead. I'm lost without it! What should I do?? I only got it in August, so only a few months old 😞
Best Answer11-18-2016 05:04
11-18-2016 05:04
Welcome to the Forums @Jo_C. Thanks for troubleshooting this inconvenience by yourself. If you have already tried the instructions provided and you keep experiencing the same problem, feel free to get in touch with our support team. For a faster response you can contact them via phone or chat.
Let me know the outcome. ![]()
Best Answer03-20-2017 15:02
03-20-2017 15:02
I've got a new blaze and it doesn't charge, yet the app says that it's has a full battery. It did increase to nearly full battery after 3 hours on charge and died shortly after! Restart etc not working can anyone help me please.
Thanks!
04:52
09:48
03-26-2017
04:52
09:48
Best Answer05-22-2018 20:32
05-22-2018 20:32
This has happened to me. They are sending me a charger to try. If this doesn’t work I’m going to be very disappointed. I had a replacement from a screen crack less than a year ago which I was thankful for but it didn’t extend the warranty On the replacement and now I’m probably going to be without and have to purchase a new one. It’s heartbrekeing because they are still pricy even with a discount offered to replace my blaze.
Best Answer08-14-2018 04:24
08-14-2018 04:24
My Fitbit Blaze has also been charging more than 12 hours and the screen is still totally blank. And it shows the battery as dead when I look through the app as well. It is less than a year old (I bought it in January). Can someone from Fitbit advise what to do next or how to get it replaced?
Best Answer06-08-2019 12:12
06-08-2019 12:12
If anyone is finding this 2 years after this post and having the same issue, try taking off the back (just have to take 4 screws off) and check where the charging contacts connect inside, as mine was doing this and there was gunk blocking it, wiped it off and now it's working fine.
07:48
07:13
AndreaFitbit
08-10-2021
07:48
07:13
AndreaFitbit
Try cleaning the pins on the backside of the watch...Too much grime will prohibit ability to charge in port.
Moderator edit: format.
Best Answer08-10-2021 17:18
08-10-2021 17:18
I tried that. My Blaze is officially dead. I have needed to put a book on the device while in the charger for about a year to get the thing to charge up. It has needed a charge about 2 x per day. It’s only 4 years old. I’m going to Apple now
Best Answer08-10-2021 21:44
08-10-2021 21:44
Where the service will be.
Best Answer08-11-2021 05:56
08-11-2021 05:56
Not service I’m looking for
Best Answer08-11-2021 06:07
08-11-2021 06:07
I can't get 1 day battery backup from my blaze
Best Answer08-11-2021 12:27
08-11-2021 12:27
Can you share what size Allan wrench you used to remove these screws? They are pretty small and not easy to manoeuvre
Best Answer08-11-2021 20:53 - edited 08-11-2021 20:53
@Lor58 Amazon sell kits with a replacement battery and the tools.
08-16-2021 11:28
08-16-2021 11:28
I could do with some help or advice also…
Blaze been great for 3 years.
In last week it loses charge within 4 hours, but the app when synced showing its 90+%.
Charges as normal then drains in no time. Nothing different being done such as notifications that are always off.
I’ve reset it and cleaned the charger and blaze itself.
Help
