02-28-2016 20:48
02-28-2016 20:48
02-29-2016 14:39
02-29-2016 14:39
Same issue for me. Blaze/Fitbit app showed that I did less than 5 miles, while the Nike+ app showed I did over 5 miles. I also have an iPhone 6. I'm more inclined to believe the Nike+ app stats.
03-01-2016 13:04
03-01-2016 13:04
03-01-2016 13:25
03-01-2016 13:25
Yup short distance here too.
03-01-2016 13:52
03-01-2016 13:52
03-01-2016 19:14
03-01-2016 19:14
Got my Blaze two days ago but due to bad weather have only used it for the first time today. I did my regular walk that I've done for some time now and I know what the distance is. S Health (samsung heath) and MapMyWalk both give me exactly the same results in the past. Today using the Blaze for the first time the distance recorded was half of what it should have been.
What is even stranger is when I look at the total Steps for the day by touching the "Today" option on the watch I get the correct distance I have done, yet the actual result in the Exercise it still shows the distance travelled at half what it is actually.
I think somehow the Exercise feature is miscalculating the GPS data for some reason but the main Today figures are getting it right. Just a guess.
03-01-2016 21:20
03-01-2016 21:20
03-08-2016 17:28
03-08-2016 17:28
03-08-2016 22:16
03-08-2016 22:16
03-31-2016 14:46
03-31-2016 14:46
Same issue for me. I have walked the same route on my lunch break for years using mapmyfitness and the distance is 1.13 miles. With the Blaze Walk tracker, I'm lucky if it records .75 miles. The closest it has gotten is .88 miles.
My run distance however seems to be quite accurate, within .05 of a mile.
01-16-2017 07:13 - edited 01-16-2017 07:14
I walked 4 miles today and it shows .70 miles.
01-16-2017 11:23
01-16-2017 11:23
I have just upgraded to a the Fitbit Blaze but I've noticed than I need to walk approx 300 more steps to make a mile compared to my other two previous fitbits. This equated to just over a quarter of a mile. I notice this post started back in 2016. Can anyone from fitbit please explain why the blaze isn't recording the same amount of miles. Step count appears to be ok but you do not get the same amount of distance for your steps.
Look forward to a reply from Fitbit
01-16-2017 16:32
01-16-2017 16:32
@Cavalierlover2I have found if I walk under a moderate pace, about 2.5 mph (4.0 kmh ) I lose about 20% of the distance. Over that, at a moderate to exercise pace the distance is accurate. Normally my planned exercise walk. But domestics, like carparks, shopping strips and malls is where I lose distance.
This has been happening since March 2016 when I first received the Blaze. All of my other trackers are accurate on distance when using at the same time and under the same conditions.
I have logged this with Support and my case is closed and the data is with Engineering.
01-16-2017 16:41
01-16-2017 16:41
