Is the device you are trying to sync to a supported device?
iOS: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_iOS.pdf
Android: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Android.pdf
Windows: https://www.fitbit.com/content/assets/onezip/images/devices/Fitbit_SupportedDevices_Windows.pdf
It's great to welcome you @Krisholoy and @SunsetRunner thanks for stopping by.
As our friend recommended, please check if your phone is a compatible mobile device and also let me know which phone you have so I can provide you the correct troubleshoot to fix this inconvenience.
Let me know the outcome. ![]()
Best AnswerHi Sir,
I owned a Xiaomi Note LTE phone and aware that this device is not in the support list. Are you saying that I will not be getting notifications forever. Please advise.Thanks
13:08
09:04
02-10-2017
13:08
09:04
Hey there @WUTANSAN! I've noticed that sometimes users may have a mobile device that's not supported. However, it eventually syncs or the notifications may work. I can't confirm they will sync normal because it's not listed as supported.
You can always keep an eye on the list of supported devices list because Fitbit is always adding new devices.
Hope this helps. Thanks for your understanding.
