06-01-2018
11:30
05:33
AlejandraFitbit
06-01-2018
11:30
05:33
AlejandraFitbit
My Blaze will not let my Samsung Galaxy 9 pair with it, any solutions?
Best Answer06-02-2018 17:22
06-02-2018 17:22
Having the same issue
Best Answer06-04-2018 05:37
06-04-2018 05:37
A warm welcome to the Community @JHMc and @CycleinSD it's great to see you around.
Could you please be more specific about the issue you are having with your trackers? Is this regarding setting them up or syncing? In the meantime, you can try the instructions provided in the following links:
Hope to hear from you soon. ![]()
06-04-2018 19:01
06-04-2018 19:01
Best Answer06-06-2018 05:05
06-06-2018 05:05
Thanks for the clarification @CycleinSD, if your Blaze isn't receiving notifications, I recommend following the instructions provided in the help article My Fitbit device isn't receiving notifications from my phone.
Also, I recommend taking a look at our list of compatible mobile devices. If your device isn't compatible, it doesn't mean that it won't work with your tracker but you might experience some connectivity issues. You can always try the instructions in the provided link.
Let me know how it goes. ![]()
