08-03-2019 11:32
08-03-2019 11:32
my Fitbit blaze stopped holding a charge about a week ago. I have shutdown the device several times, updated the device, etc and still no luck. What am I missing here? It appears several other users are experiencing the same issue. I use an iPhone to sync the device.
Best Answer08-05-2019 03:31
08-05-2019 03:31
I don't think you're missing anything...... There are too many posts with this issue.
Best Answer08-05-2019 05:10
08-05-2019 05:10
My Blaze has also stopped holding a charge. It would last on average 6 days between charges, then around the beginning of July something just tanked and now it only holds a charge about 4 hours. Hasn't gotten wet or experienced any physical damage. I even replaced the battery (which does require soldering), and still only lasts about 4 hours. Reset it, unpaired, checked firmware but nothing seems to help. Currently running firmware version 17.8.402.1. My Blaze is just over 2 years old, so out of warranty. After speaking with Fitbit, was offered a discount on a new one.
Best Answer08-05-2019 07:51
08-05-2019 07:51
Mine does the same. This just started for me too. I have tried everything with no luck. Yes they may offer a discount but I think the latest software updates are the main issue. I believe they are trying to phase out this model since it's no longer available.
Best Answer08-05-2019 12:41
08-05-2019 12:41
Mine started a while ago, and it is over 2 years old too. I was attributing it to battery longevity, but based on other posts here now I wonder. The degradation did come on pretty fast. I was about to try replacing the battery myself (handy with a soldering iron), but after the last post, I dont think I am going to do that now. SMH
Best Answer08-05-2019 13:15
08-05-2019 13:15
Best Answer08-05-2019 15:19
08-05-2019 15:19
I am starting to wonder if it was the new product effect like when apple makes a new phone and suddenly your old one doesn’t work haha! My blaze lasted at a minimum of 3 years maybe closer to 4, in perfect condition until this past week and EVERYONE is having the same problem.
Best Answer08-06-2019 05:46
08-06-2019 05:46
I also have Verizon with a Galaxy S8 and have received a few software updates on my phone. I haven't had a firmware update on my Blaze in a long time. I did, however, get almost 12 hours exactly before it shut off again on my replacement battery. So maybe there is a little hope still, although I'll be surprised if I even get the normal 6 days off a charge again.
