My Blaze has worked perfectly for ages, but it's now saying it won't charge. I can hear that the USB is working when i plug it in to the PC, and I've also tried plugging in to the wall but nothing...
any ideas?
04:09
04:42
10-27-2016
04:09
04:42
It's great to see you around @lozbomb and thanks for troubleshooting this inconvenience by yourself. I recommend restarting your Blaze and after the restart process, clean the charging contacts on the back of your Fitbit Blaze, since over time the contacts can accumulate dirt and debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
I hope this helps, let me know how it goes. ![]()
