Very sad! Got blaze for Christmas as a gift. Excited to use but couldn't get it to charge. Got replacement. Still wouldn't charge. Got 3rd replacement. ...guess what???? Still won't charge. Now have to return 3 blaze fitbit. Will NOT be asking for anymore replacements. You have now lost a customer fitbit!!!!
Hi there @Suz6. Good to see you in the Fitbit Community!
If your Blaze is brand new, you will not see a battery icon on the display showing that it's charging. What you will see is the "fitbit.com/setup" message. It should vibrate when plugging it to any USB port though. You should then leave it charging for about an hour at least and after that attempt to set it up.
Try that out and let me know how it goes!
I have the same problem, there is no vibration when it is plugged in but the unit does come on. I have reset it several times. still no charge.
Best Answer@Suz6 please read @FerdinandFitbit post above again.
I'f your tracker is not setup, and still shows the www.fitbut.com/setup screen, there will not be a battery charge indicator on the screen, but it will be charging.
Also your tracker night not need to be charged before setting up, the app will tell you.
Personsly I would recommend a 30-60 minute charge using your phones charger.
