08-19-2018
14:09
04:58
AlejandraFitbit
08-19-2018
14:09
04:58
AlejandraFitbit
Charged Blaze overnight in cradle and wall plug. Still showing single red line battery pic. Plugged into USB to charge today, same result. When I push the left button and right lower button the dead battery symbol appears, disappears, and the unit won't shut off or show the Fitbit logo. If I put it back into charger cradle it shows the Fitbit logo then goes to time screen, including the small dead battery display, and that's it. Any ideas on how to proceed?
08-20-2018 04:59
08-20-2018 04:59
It's great to welcome you @DebBett.
If your Blaze isn't charging, I recommend taking a look at the help article Why isn't my battery charging? and follow the instructions provide there, also restart it by doing the following:
Let me know the outcome.
08-20-2018 06:23
08-20-2018 06:23
08-20-2018 06:27
08-20-2018 06:27
Thanks Alejandra! I did go through the recommended steps to no avail. And I'v tried to shut down but it doesn't work as described. When I push the left side button and the right side bottom button the red battery symbol shows for a moment and then disappears. No matter how long I continue to hold the fitbit icon never shows up and the watch does not power down. I'm also unable to sync. It says "looking" but never finds the watch.
08-20-2018 09:25
08-20-2018 09:25
My Blaze is doing the exact same thing. On Wed last week I was able to get full charge and it just finally died today. It will not charge. I cleaned the terminals and followed all of the instructions. Fitbit's in my experience only last one year or shortly longer. I believe I purchased this one in June of 2017 and my previous charge was replaced under warranty, and the replacement barely made it the next year.
Please advise if this is able to be repaired or if it is time to find something else.
08-20-2018 17:57
08-20-2018 17:57
Having the same problem! And I just got it for my bday on July 16. So it's not old. Please help.
08-21-2018 18:18
08-21-2018 18:18
My Blaze won't charge either. Looked at contacts on the device and they seem pitted and unable to make contact. I had an episode with a fib and bought the Blaze to monitor heart rate. Can provide picture of needed. Please advise.
08-22-2018 00:53
08-22-2018 00:53
It appears fitbit only responds to new threads - not comments in other threads of the same issue. I am going to copy my comments to a new thread to get a response.
