04-22-2016 08:25
04-22-2016 08:25
Best Answer04-23-2016 08:40
04-23-2016 08:40
Thoughts?
Through what are you charging the Blaze with?
Computer, laptop, or wall wort?
Does the icon on the blaze show that it is indeed charging?
If your using a computer or laptop, the charging might stop when the computer does to sleep.
How long should it take usually 2 hours should be sufficient time
Best Answer04-24-2016 05:00
04-24-2016 05:00
Welcome to the Community @FHGrl. I agree with @Rich_Laue, 9 hours is too much time to charge your tracker, since it usually takes 1 or 2 hours to fully charge. I recommend contacting our Support Team, since they have the proper tools to see if your tracker fully charged or not.
Let me know how it goes. ![]()
04-24-2016 09:29
04-24-2016 09:29
Best Answer04-24-2016 11:12
04-24-2016 11:35
04-24-2016 11:35
Best Answer04-24-2016 12:57
04-24-2016 12:57
Best Answer04-24-2016 15:27
04-24-2016 15:27
@Nolander @FHGrl The Fitbit App shows the battery level from the last time you synced your tracker. It's definitely possible that you just need to sync your tracker for the battery indicator in the App to update. If you are having trouble syncing, click here for help.
Keep me posted if you need any additional assistance!
04-24-2016 16:13
04-24-2016 16:13
Best Answer04-24-2016 16:58
04-24-2016 16:58
Best Answer01-27-2018 20:15
01-27-2018 20:15
How do you solve the problem ? im having the same issue
