09-04-2018
12:39
05:13
AlejandraFitbit
09-04-2018
12:39
05:13
AlejandraFitbit
My Blaze got wet in pool. I realized right away and dried it for a while. I charged it and while it works fine the battery dies quickly. Does anyone know if replacing battery will help?
Best Answer02-04-2019 08:49
02-04-2019 08:49
My Fitbit blaze won’t hold charge after getting wet. Charge lasts less than a day. I’ve tried letting it drain all the way and then charge fully. Syncing also. Anything I can do? It’s not that old.
Best Answer09-05-2018 05:14
09-05-2018 05:14
Welcome to the Community @Tcq592.
Thanks for troubleshooting this by yourself. I recommend taking a look at the help article What should I do if my tracker was washed or submerged in water? and follow the instructions provide there. About the battery, in this post are some steps you can follow.
Let me know the outcome. ![]()
02-04-2019 08:49
