01-16-2020 11:35
01-16-2020 11:35
My Blaze won't return to the previous view when the left button is pushed, nor will it reset. I've checked that the button is being depressed-it is! Any ideas of what else I can try? Thanks for your help
01-16-2020 16:55
01-16-2020 16:55
Same here. What is going on?
01-17-2020 09:40
01-17-2020 09:40
I had a similar problem last fall. In my case, some internal piece was stuck so that it would be hyper-sensitive to contact with the left button. Later on, it changed to being very difficult to press the left button at all (I could press the button, but the contacts on the inside weren't registering it). Eventually, the button stopped working completely, which means I can no longer go into sub-modules (such as Today, exercise tracker, or alarms) because they require pressing the left button to exit out.
I doubt there's an actual "fix" because devices like these weren't really built to be repaired.
01-17-2020 10:54
01-17-2020 10:54
01-19-2020 11:59
01-19-2020 11:59
Have you tried restarting the Blaze through its settings / help? This can be done without pressing any buttons.
01-19-2020 12:16
01-19-2020 12:16
