04-10-2017 10:10
04-10-2017 10:10
I just purchased a Blaze and i'm having issues setting it up on my Samsung S7 Edge. I let the device charge for an hour. Now I keep getting the setup website. on the app where I am trying to install my new device, it keeps saying that its not on. I can't hard reset the device or connect it via Bluetooth. Does anyone else have this problem.
Best Answer04-10-2017 11:50
04-10-2017 11:50
@JenniferW123, I am not sure I understand your question. Are you able to turn your Blaze on? If not, you have not charged it sufficiently. Don't forget that in most cases a computer or laptop will not deliver charge while it is inactive/sleeping .
If the Blaze is not turned on / does not have sufficient power, you will not be able to set it up.
Best Answer04-10-2017 11:54
04-10-2017 11:54
As for setting it up, have you downloaded the Fitbit app, logged into your account, now do an add device from the accounts tab.
Best Answer04-10-2017 13:02
04-10-2017 13:02
@Rich_Laue, since rhe OP mentions what she is seeing on the app, I think it is fair to assume she has downloaded the app. 😉
