07-17-2017 04:47
07-17-2017 04:47
My blaze won't even stay on at this point it just keeps shutting off. I get a symbol of a thermometer? Fitbit has sent me a new watch but at this point I don't even want it anymore for $300 I expect a watch to last longer than 3 months. The watch has alot of problems like having to restart the Bluetooth connection almost every time I go for a run or a bike ride. Pretty sad.
07-17-2017 09:20
07-17-2017 11:05
07-17-2017 11:05
07-17-2017 11:13
07-17-2017 11:13
Update me when you receive your replacement Blaze. If your new Blaze syncs perfectly fine while showing you the correct time and stats, that means the previous problem was with your Blaze. If the new Blaze has the same problem, then it’s your phone or a setting in your Fitbit app.
Michael Groff | CO, USA
Fitness isn’t being better than someone else, it’s being better than you used to be!
07-17-2017 11:25
07-17-2017 11:25
Is the thermometer problem gone @Luch84?
I understand the unpairing of the tracker fr9m the ph9nes bluetooth, bu5 the pairing must be done by the app, it is not something that you cand do. I'm not sure what you mean by unpairing?
Im assuming that the tracker is still setup and attached to your Fitbit account.
07-17-2017 11:46
07-17-2017 11:46
