12-31-2020 06:30
12-31-2020 06:30
Hi,
my Blaze doesn't want to track my routes even if the phone GPS is on and connected with tracker.
I tap "Exercise" on the tracker, choose "Bike" - the tracker is Connecting to phone for a couple of seconds, then shows it is connected and says "Let's go".
I then start cyckling and after 30 minutes I arrive at home and the result is 160 metres tracked, 0 calories, no GPS track.
Still when I sync it after the cycle the app shows the starting point correctly and the finish point correctly as well with a straight line drawn between them and nothing more. As if I cycled no distance.
Anyone with this kind of trouble (the app as aupdated, Huwawei Mate 20 Lite)
01-19-2021 10:21
01-19-2021 10:21
Same problem
01-20-2021 00:23
01-20-2021 00:23
My Blaze won't track routes either. My phone says that Fitbit GPS is tracking when I am walking/running and my exercises will tell me distance covered however I no longer get a map of my exercise.
02-01-2021 09:28
02-01-2021 09:28
Mine too! So frustrating. Did you find out why this is ?
mine is a few years old now so maybe an upgrade is due ?
02-02-2021 07:10
02-02-2021 07:10
No solution so far 😞
mine is a few years old as well, but this feature has never worked really, on any smartphone I've had,
even if updated.
02-11-2021 08:23
02-11-2021 08:23
04-01-2021 07:28
04-01-2021 07:28
hey guys,
just wanted to let you know that I have completely given up looking for a solution and explanations,
and simply switched to Versa 3.
Not exactly the move I would call the best, but well... at least I now have my trekking, running, cycling routes complete, tracked and saved.
04-01-2021 13:27
04-01-2021 13:27
I'm assuming everyone knows this but as only a few people mentioned phones, the Blaze only records GPS with a phone attached, unlike the Surge, Ionic, and Versas with a built-in GPS. Assuming you're using your connected phones, have y'all attempted to remove the application and reinstalling? Weirdly, this fixes many issues.
04-02-2021 02:33
04-02-2021 02:33
I've tried about 9 times, switched phones and deleted and paired the device again - nothing.
